Replace item in Windchill BOM
Claude76FR
When an existing item is added again using “Insert Existing” option, a warning message is shown.
But when an item is replaced with an existing item using “Replace with Existing” option, no warning message is shown, and the item got duplicated
Are you working on it to solve in the future version?
thank you,
Claude
If you can give screen shots on the warnings, it will be easier to understand.
Best Regards
Hari
Claude76FR
(To:Hari_Vara)
Hello Hari,
When an existing item is added again using “Insert Existing” option, below warning message appear
But when an item is replaced with an existing item using “Replace with Existing” option, no warning message was shown, and the item got duplicated
Should be good if same warning message appear also in this case
Let me know if it is clearer
Claude
This message is intended solely for the addressees whose the e-mail addresses are indicated above. If you have received this message by mistake, please delete it immediately and notify the sender. The information contained in this message should be considered as confidential. Any use in any way or transmission to a third party, is strictly prohibited. Due to the electronic transmission of this message, Carrier Transicold Europe declines all liability for any corruption which could affect the content of this message. Any views expressed in this message are those of the individual sender, except where the sender states them, with requisite authority, to be those of Carrier Transicold Europe. If the e-mail is addressed to a client, any opinion or advice contained in this e-mail is subject to the terms and conditions expressed in the governing client agreement.
By replying to this e-mail or by sending an e-mail to any employee, agent or representative of [Carrier Transicold and its affiliates], you consent to our collecting, processing and transferring outside of the European Economic Area, your personal data for the purposes of performing any agreements with you or your organization, marketing and advertisement, internal training, customer profiling as well as the prevention of abuse, fraud, money laundering or terrorism financing. Your data will be accessible to members of our sales, marketing, IT and legal departments and our data hosting service providers. You have the right to access to your personal data, correct any inaccurate or incomplete personal data or object to their processing on legitimate grounds by sending an e-mail to: personaldata@carrier.com
HelesicPetr
(To:Claude76FR)
Hi @Claude76FR
Create an Idea that covers your needs.
If the idea does not exists the information alert will never be delivered.
I can imagine that the function with replace does not inform you because it is expected that you know what you are doing and you replace part to another by some change request..
If you add a "new" part, system inform you that the item is already in the BOM because it can be mistake. or not. depends on how the BOM is used...
PetrH
Hi Claude,
Does it happen when you just increase the QTY in the QTY column instead of "Add Existing".?. (I think It wont give that warning!).
Another thing is that if you add the existing part under another parent part (I think it wont give that warning !).
We will talk about "Replace" scenario after settling the above, hope it makes sense.
Cheers!
Hari
