Replication Error - Not in GZIP format
pyalavarthi
Hi all,
I am doing a replication server setup. When I setup the
replication scheduler, it is giving following errors while trying to copy
files from Master to replica server.
Has anyone seen this error. Any info would be helpful.
028 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19: Nested
exception is: wt.wrmf.transport.WTTransportException: java.io.IOException:
Not in GZIP forma
56028 t
56029 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
Nested exception is: java.io.IOEx
ception: Not in GZIP format
56030 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at java.util.zip.GZIPInputSt
ream.readHeader(GZIPInputStream.java:137)
56031 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
ream.<init>(GZIPInputStream.java:58)
56032 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
ream.<init>(GZIPInputStream.java:68)
56033 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.wrmf.transport.httptra
nsport.ReconnectedHttpURLCon.getInputStream(ReconnectedHttpURLCon.
56033 java:183)
56034 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
nsport.HTTPPipeAdapter.pullInGeneral(HTTPPipeAdapter.java:780)
56035 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
nsport.GZIPHTTPPipe.pull(GZIPHTTPPipe.java:446)
56036 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.wrmf.transport.Standar
dGenericTransportService.pull0(StandardGenericTransportService.jav
56036 a:460)
56037 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
dGenericTransportService.pullInitialize(StandardGenericTransportSe
56037 rvice.java:318)
56038 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.wrmf.delivery.Outbox.s
end0(Outbox.java:477)
56039 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
endToGTS(Outbox.java:365)
56040 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.wrmf.delivery.Transpar
entOutbox.send(TransparentOutbox.java:328)
56041 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.wrmf.delivery.Standard
ShippingService.sendImmediateItem(StandardShippingService.java:685
56041 )
56042 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at wt.fv.replica.StandardRep
licaService.pullStream(StandardReplicaService.java:1702)
56043 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
licaService.remotePullAndStoreStream(StandardReplicaService.java:1
56043 901)
56044 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at sun.reflect.GeneratedMeth
odAccessor64.invoke(Unknown Source)
56045 Tue 8/9/11 19:47:16: RMI TCP Connection(528)-172.18.98.19:
at sun.reflect.DelegatingMet
hodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
Prathap <">http://goo.gl/LuT5>
0 REPLIES 0
