I would like to take a representation of a drawing file which contains a image file with it. When i tried the representation is not showing the image files with it.
Can anyone will help me in finding out the solution for this
It takes a couple of additional clicks to get to the image files. Navigate to content tab, LMB on the representation, select save representation. use zip or jar, this will give you a zip file with image files in it.
No watermark with this method. Do you think there is a way we can get the watermark on it using this method?
Hi Ben Perry,
To get watermark, you need to use post publish/loader method to watermark all your PDFs. If you have a Adobe LiveCycle, it is an easy configuration. If you don't, we can get it done using a couple of methods and iText APIs. I do have something using iText in our development server, let me know, I can share some details.
Binesh
Currently we don't have LiveCycle.
