Republish only drawings using WVS Job Scheduler Administration
ThoaiVuong
2-Explorer
We recently deleted all viewables of EPM Doc's (all Pro/E, Creo) from the system because they were published with rules that we've now changed.
On a rehosted test server we tested republishing all - takes a while. We'd like now to only republish drawings, and if possible only the latest Version of each.
On the Job Scheduler UI, there are a number of OTB "Jobs" including: PublishAllEPMDocsLatestNoRepresentation. This is what we want but would like to exclude .PRT, .ASM.
We've asked PTC tech support how to create a custom job but haven't yet heard back.
Question: Does anyone have such a custom job? Would you be willing to share?
thanks
TomU
(To:ThoaiVuong)
I too would like to be able to create custom publishing jobs but unfortunately this requires understanding Java and the Windchill API. From the 10.2 customization guide (p1336):
If you have a different version, you might want to read through CS32335:
LoriSood
23-Emerald I
(To:ThoaiVuong)
As Tom mentioned, it will require some Java knowledge to create a custom publish filter. There are also some WVS properties that can be set to exclude certain types, depending on how you wish to publish and which version of Windchill you are running. Please see the following for further information:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS39455
