Request for Modifier Order Configuration
AN_10514103
2-Explorer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
The business has requested that modifiers be placed in the correct order within Windchill. The expected order is as follows:
Numeric values: Starting with the lowest numbers.
Alphabetic values: Followed by alphabetical entries.
Currently, this functionality is not available in Windchill. Kindly provide guidance or assistance in enabling this configuration.
Hi @AN_10514103
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
You need to be specific about what a "modifier" is. What field are you talking about? It seems you are looking to alter the sorting algorithm where numbers are sorted as numbers not as text. This problem is common in Excel when sorting data. But you need to provide screen shots and examples of what you are looking to do.
