There is a critical situation with my organization that I have a workflow which is being triggered from the library and I want to resolve the roles in the workflow activities from a team template which is created at Product context level.
Is it possible using some codes or something ??
Participation of the community members will be appreciated.
This article may get you started. It lists the APIs used to get the team template and then the roles from that template:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS197190
Thank you Lori, actually we skipped this step for a while but started development again on the same.
Thanks again for your concern on the same.
