Return top X results from Query Builder report
mmeadows-3
Version: Windchill 13.0
Use Case: I have a query that can return thousands of results but only need to see the first 10 to 20 based on sort order.
Description:
I can return the top 10 results in TSQL with:
SELECT TOP 10 {column} ... ORDER BY {column} DESC
Can we do this with Query Builder?
Hmm, if we had the ability to display the row number, it would be possible to put a condition that shows row numbers less than a value. ROW_NUMBER() or ROWNUM is a function but not one that is listed. I tried using it as a constant and it did not like it. No way to trick it to reading it like pure sql.
You might be able to use a custom java class for this:
https://www.ptc.com/en/support/article/CS114482
