Hello, I'd create a new reusable attributes (type) to put a link to a file in share lan folder.
for examples:
\\test.com\data\temp\xxx.pfd
I done all but it doens't work, when I tri to click on oi, Windchill give me this error:
How can I add an attributes with a link to open a PDF file?
Hi @Alberto
Check a final link that is opened. There would be prefix with server/Windchill/...
Try to use "file://" in the beginning of the URL
Generally I had trouble to use OOTB URL attribute.
The OOTB behavior couldn't meet customer needs and could be difficult to use URL attribute to point an external storage that way.
I would use custom DataUtility which builds correct URL link for a user.
PetrH
Thanks a lot for your answer 😉
The only one limitation is that I need to use Internet Explorer (as mentioned in the CS134794). This is no good but I don't find another solution.
