Rev issue in format
JOES
Rev issue in format
I've got three drawings (with three parts) that I created a while back on my
home machine (WF4 M120 64bit). Now a user (WF4.0 M040 32bit) is making a
change to the drawing (some notes) & when he up's the rev from A to B the
format still shows A. When he uses page set-up to remove & replace the
format &PROI_REVISION. The same happens on my work machine (WF4.0 M040
32bit). Back here at home it I upped the rev to B & it works fine.
We are using Intralink 3.4 M060.
I might call PTC but I am unsure they will help.
Thanks & have a good weekend,
Joe S.
JOES
(To:JOES)
Let me add that we've been using Intralink (starting at 3.0) for about 10
years & understand how to properly up the rev in Intralink without the model
or drawing in memory.
I've actually attempted to fix this problem by changing it at home &
checking it in. The model & drawing of all three are at Rev B which shows
up fine on my home machine but not on the work machines.
Joe S.
JOES
(To:JOES)
Solved it. I had to update my machine at work to the WF4 M200. Now all I
gotta do is update everyone elses machines...
Since I found a solution I thought I should post it for the archives in case
anyone else comes across it.
Joe S.
