Run/Execute *.qml file through java code
DarshanT
7-Bedrock
Hi Expertes,
I would like to understand is it possible to execute/run the QML (Windchill report) through java code? I'm aware of importing/loading into windchill but i'm interested to execute the qml through java and get the response. I have tried exploring the report code but got no clue.
Manjunath Reddy
Hi Manjunath
please take a look at the webject
<ie:webject name="Generate-Report" type="OBJ">
The Generate-Report webject executes a Windchill Report Template and returns
the results as an Info*Engine group. WCAdapterGuide details out the syntax
of the webject.
HTH
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
jessh
(To:DarshanT)
There are supported Java APIs for this purpose as well.
See wt.query.template.ReportTemplateHelper, for instance.
Jess Holle
Hi All,
Thank you for all your suggestion and ReportTemplateHelper.convertToReader did the trick.
Manjunath Reddy
tschwei
(To:DarshanT)
Hi Manjunath and others.
I'm also struggling with running a saved report template via java code.  Manjunath, how did you use convertToReader()?
ReportTemplateHelper class has limited Javadoc, and I don't see ANY Javadoc for ReportTemplateHelper.convertToReader()?
By guessing on the input hashmap and other parameters, I have been able to get a report to run using ReportTemplateHelper.generateTableModel(), but I can't figure out how to export it as a CSV file.
Is there any sample code that runs a report using ReportTemplateHelper and saves the results to a file?
Tim
