Hello
I am looking for sql or ?? to view objects in users workspaces. Hopefully the version/revision of those objects.
I know I can do it on windchill, but sure about intralink. Then compare to files of same name/number
in commonspace.
The purpose it to see which users have models they have not ever checked into commonspace &/or
not checked in the latest ver/rev.
I am migrating from ilink 3.4 to 9.1 & need to know which users are ignoring requests for all work
to be checked in.
I had contacted M Mettes (which im sure he'll have an idea about this sql code, if its possible), But
it was to his work email & he might not see it till monday. I can wait till then, but thought I would try
all inlink gurus also.
L Jett
cadjett@aol.com,datajett@aol.com
I guess an alternate route would be to write/run sql to see what objects in commonspace, that are checked out into a workspace.
IM trying to see who has not checked in latest work & also who has models in workspace, that has never been checked in.
If there is no sql ot toolkit, etc that can read the contents of a workspace, maybe I can still see objects in db that have been checked
out to a workspace.
L Jett
Hi
I'd suggest SQL can't help you here: it looks in the dataserver, while you're trying to look atindividual workspaces.
When I previously prepared for major Intralink upgrades, I used an Intralink UI Script to check the status of colleagues workspaces across 12 servers.
It was called on startup, and would run silently, logging in as a guest user and printing workspace contents to text files, relaying them back to a server. Then scripts produced web-page lists of usernames, workspace/new/modified item counts, clickable links to show, etc, etc. It would run only once a week, or as required...
It helped me follow up with individuals at risk of losing data during impending upgrades.
I've searched my computers but can't find the .java file - if I do come across it I'll post.
Regards
Edwin Muirhead, CAD Manager, Weatherford
In Reply to Lawrence Jett:
IM looking for an intralink 3.4 solution to viewing users workspace objects.
There are many methods to viewing, checking in (upgrade classes/methods), etc for workspaces in windchill.
I just need to know if users are not checking in their work from their intralink 3.4 workspaces.
L Jett
