UDA added to Promotion Request not showing on 1st screen.
RandyJones
20-Turquoise
Using the Type and Attribute administrator I have created a new string
attribute called ResponsibleTeam and added this to the Promotion Request
as a discrete set, single valued, and required. However when I select an
object and then create a Promotion request this attribute is not showing
on the first screen for the user to select.
If I add this same attribute to the Problem Report then I get a required
selection on the 1st screen of the Problem Report as expected.
Anybody have any hints/tips on what I have missed doing here???
I have made sure the PromotionRequest is checked in and I have also
stopped Windchill and Tomcat, removed the Tomcat/work/Catalina dir
and then restarted Windchill and Tomcat. Although restarting was not
necessary in order for the attribute to show on the Problem Report.
I put in a call on this a long time back...
The PromotionNotice object accepts attributes in the Type Manager but doesn't actually allow their use.
Be aware of:
TPI 147734 - How to Customize the Promotion Notice Create Wizard UI
As of Windchill 9.1 Maintenance Release M040 the Promotion Notice Create
Wizard UI is not supported for customization
Saul
