Search Error: Status code: 501 unable to determine the context type
kregimbald
Windchill 10.1, Internet Explorer 9
While trying to initiate a simple search I received the following error:
Status Code: 501
Message: com.ptc.jca.mvc.components.TypeBasedRedirectionInterceptor: unable to determine the context type for based lookups
I closed Windchill and re-launched. Tried it again and the search worked.
The problem is this error message is popping up frequently.
Note: I have chosen the correct context type when running the search. The search itself only provides a few search results (maybe 2-4 files).
Anyone know what might be causing the error?
pmöllberg
(To:kregimbald)
Hello
I have a user with the exact same problem. How did you solve it on you end?
Pär
