I'm working on some code in a workflow and I want to be able to query baselines that meet certain conditions. When I use syntax like the below, the workflow goes to an "aborted" state with no indication as to why. How would I query baselines?
wt.query.SearchCondition sc = new wt.query.SearchCondition(wt.vc.baseline.ManagedBaseline.class, "lifeCycleState", wt.query.SearchCondition.EQUAL, "Approved", false);
Joe,
So, you're trying to query based on a case insensitive value of the lifecycle state.
You need to replace "lifeCycleState" with:
"state.state"
Hope this helps
David
Joe,
"state.state"
Hope this helps
David
Thanks!
I found another way to get what I needed, but I tested the code you gave, and it didn't cause the workflow to abort.
Thanks for the help!
