Great discussion, just to clarify, docs say this:
The Search Criteria table allows you to build detailed search queries by
selecting specific searchable attributes and specifying the attribute
values on which to search.
Note: Multiple values can be specified for attributes by adding the
attribute to the table more than once. If you specify multiple values
for a single attribute, there is an implicit OR relationship between the
two values. For example, if you specify the Name attribute twice, with
values of part* and gear*, your search returns results which match
either of those values.
So, this wt.property setting switches it to an implicit AND
relationship?
Olaf, where did you pick up the convention of delimiting multiple search
criteria with a semicolon? I could not find that documented. This allows
you to do ANDs and Ors now. Great work.
