Searching with Multiple Criteria using AND statement?
ocorten-2
9-Granite
Is there a way to change the behaviour for multiple Search Criteria in Windchill?
Currently multiple criteria are treated with an OR statement (even though With All of These Criteria is set)
But I would like to use multiple criteria with an AND statment.
e.g. Search forFile Name equals 1003* or 1005*
ANDFile Name does not equal *xx* or *yy*
The search below in WC gives an error (search result size has exceeded the limit) because it treats both criteria with an OR statement and thus yield too many results with the second criteria:
(... we are on Windchill Intralink 9.1 M050)
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
Phone: +31 26 3196215
Mobile: +31 644548554
www.besi.com
*** nov. 10th - PTC/USER Benelux Event 2010 -
9 REPLIES 9
Olaf,
Add the following property to the wt.properties file:
com.ptc.windchill.search.client.overrideAndOrOperator=true
Dominic Hand
PLM Deployment & Support Leader
Climate Solutions
Ingersoll Rand
314 West 90th Street
Minneapolis, MN 55420
Office +1.952.887.2247
Mobile +1.612.384.4366
Fax +1.866.806.9284
avillanueva
22-Sapphire I
(To:ocorten-2)
Great discussion, just to clarify, docs say this:
The Search Criteria table allows you to build detailed search queries by
selecting specific searchable attributes and specifying the attribute
values on which to search.
Note: Multiple values can be specified for attributes by adding the
attribute to the table more than once. If you specify multiple values
for a single attribute, there is an implicit OR relationship between the
two values. For example, if you specify the Name attribute twice, with
values of part* and gear*, your search returns results which match
either of those values.
So, this wt.property setting switches it to an implicit AND
relationship?
Olaf, where did you pick up the convention of delimiting multiple search
criteria with a semicolon? I could not find that documented. This allows
you to do ANDs and Ors now. Great work.
Antonio,
Yes, that is correct. The property below changes the advanced search behavior such that it treats multiple criteria for the same attribute with an AND relationship instead of the default OR relationship. This has been tested and implemented successfully in PDMLink 9.1 M040.
Dominic Hand
Climate Solutions
Ingersoll Rand
Fax +1.866.806.9284
Great man, just what I was looking for. Will try it asap.
The semicolon was discovered by one of our users who just copied the Intralink 3,.4 functionality and tried in 9.1.
BTW, The semicolon does not work in the Keyword field unfortunately. So the search below returns nothing:
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
www.besi.com
To: "Villanueva, Antonio" <->, Olaf Corten <->, "-" <->
Date: 14-10-2010 16:40
Subject: [solutions] - RE: Searching with Multiple Criteria using AND statement?
Antonio,
Yes, that is correct. The property below changes the advanced search behavior such that it treats multiple criteria for the same at...
saw
11-Garnet
11-Garnet
(To:ocorten-2)
I have noticed that this search is much slower than a single criteria name or number search.
Stephen Worthington
May be related to wildcards. Seems to be immediate for a long list if the entire Number is included.
saw
11-Garnet
11-Garnet
(To:ocorten-2)
I have used a full file name including extension just to try my theory and it still seems slow.
Stephen Worthington
Name and number input fields searches only mastered objects I believe, where the regular keyword field when a name or number is used searches more objects regardless if fast search is installed or not. I guess PTC could chime in on that angle.
Sent from my Verizon Wireless BlackBerry
Olaf great thread
May I point out that there is a better way to solve some of these issues.
Many companies today force their end users to use metadata in the parts and
assemblies in hopes of
being able to search on many areas so they can find the necessary
information at a later date,
The problem lies within the fact that many things cannot be processed into
canned fields
and as such are prone to human interaction and ways of thinking, not to
mention international companies
such as on these forums where a boot in Texas and a boot in Europe are
completely different items.
We recently showed a large international company their own database of
parts, we asked them for any part
name and showed them the results based upon that part name, we then did a 3D
geometry search on
that part and found 5X the number of parts due to simple syntax differences.
( and many duplicates )
We don't take away the option to search on text/metadata we simply enhance
the search criteria
and chances for success by bringing in the aspect of a search engine that is
100% accurate based on shape of 3D part.
We have had a booth at PTC world for the last 3 years
This is installed at some very prominent companies utilizing many different
PDM systems.
If you are interested take a glance at the website and video
if you want to continue to struggle with identifying parts and
assemblies based upon textual fields . then delete this email
Kelly 713-784-3500
www.3dcadseek.com
