Security Labels with Part Create from Spreadsheet
avillanueva
23-Emerald I
Does anyone or has tried creating parts with security labels via the context "Import Parts From Spreadsheet" (IXB)? I am not referring to the XML or CSV import method described in the guide. This was a method of import from browser via XLS for Parts and BOMs. It had the ability to load IBA values too but was unsure about Security Label settings. Has anyone done this? Can you send a sample sheet for formatting? I've worked with this import method for a while and it works great.
Antonio Villanueva - Sr. Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Road, Danbury, CT 06804
Tel: +1 203 797 5682
antonio.villanueva@utas.utc.com<">mailto:antonio.villanueva@utas.utc.com> www.utcaerospacesystems.com
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
Don't you love it when you can solve your own question. Today goes in the plus column. Thank you 7zip and JD-GUI!
Type
Name
Number
Assembly Mode
Location
Organization ID
Revision
View
State
Source
CAGE_CODE
Security Labels
wt.part.WTPart
M22759/33-26-912,WIRE#26AWG(WHT/BRN/RED)
MYPART
component
Design
RELEASED
make
12345
EXPORT_CONTROL=LICENSE REQUIRED-STATE(ITAR)
wt.part.WTPart
M22759/33-26-917,WIRE#26AWG(WHT/BRN/VIO)
MYPART2
component
Design
RELEASED
make
12345
