Server Registry
DonSenchuk
Server Registry
All,
I've got one user encountering a problem where his Server Registry keeps changing name. Because of the various search paths set for formats, start parts and so forth, this causes him to be unable to quickly access those files.
I've tried renaming the registered server. I've tried deleting and recreating his server registry. I've tried deleting his local cache. Obviously I'm missing some file out there that need to be given the axe. Any help would be appreciated.
Don Senchuk
On 06/27/14 08:43, Senchuk, Donald wrote:
> All,
You don't specify what release you are running so I am going to assume you are on Creo Parametric
2.0 (from your title). Take a look at page 14 of David Haigh's Creo admin presentation available here:
http://communities.ptc.com/servlet/JiveServlet/download/3205-5-45122/CUST134_Creo_Creo_Admin_101_Haigh.pdf
BenLoosli
(To:DonSenchuk)
Also use dm_remember_server set to yes in config.pro.
