when I open the file .asm refers to an old project (inserted in the windchill system two years ago)
there is a conflict Server error: Cannot retrieve family table neutral data.
Please could you send me a solution to this problem?
You can start researching a solution to your problem using the knowledge base of PTC support.
This is what comes out as a result using the error message you wrote
Thank you Marco
I'll try to follow your kind indication
