Set default Value of EndItem to YES in creation
qtran
7-Bedrock
Hello
I want to know the command in OIR to set the enditem attribute automatically to yes in creation of a subtype.
Prabhash
(To:Prabhash)
By the way i can see a blank value above Yes. What happens when you select it?
Prabhash
(To:qtran)
qtran
7-Bedrock
(To:Prabhash)
Hello Thanks for the Answer
I want the attribute EndItem will set always setting to Yes for this subtype ( the creator can t modify it on creation or edit)
regards
qtran
7-Bedrock
(To:qtran)
Hi
I tried to follow the instruction in the article, but I can t set the default attribute (endItem) of the part master to blank. There are only 2 options: yes or no:
Prabhash
(To:qtran)
What windchill version you are using? I was able to do it on 10.1 M020 without any hitch.
Prabhash
(To:Prabhash)
