Does anyone know where we can control the size of a popup window? When we are in a library, and we need to move the object to a different folder or context, we right click on the object and select "Move". Then, under the "New Location" column, we click the folder icon to choose a new folder or context. We ALWAYS have to expand the "Set Location" window to see all of the options. We would like to be able to have it open already expanded. This is on WIndchill 10.2.
Binesh,
Do you know which setting applies to the Set Location?
