I think for Mozilla/Firefox at least,
wt.taglib.util.plugin.attr.jreversion is enforced as the minimum version.
I'm not sure about with MSIE.
Villanueva, Antonio wrote:
> If you use the dynamic setting for JRE versions (wt.taglib), does that
> take any JRE or can it be specified to take any at a level or above?
> I am certain that static will be ok but I would like to allow users to
> use 1.5 or 1.6 or anything higher than a certain version, just not
> 1.4. I would want them to be prompted to upgrade if it didn't match.
> So is this possible with the dynamic setting?
