I have a weird one that I hope someone has come across as I have.
A user wants to create a shrinkwrap of an assembly using File>Save As>Shrinkwrap. When he does this it saves the shrinkwrap as an attachment to the assembly.
Any takers? I am stumped mostly because when I try it on my system is saves it out as an independent part like I am used to.
Found the answer. There is a checkbox when you choose to save a part or an assmebly as a shirnkwrap that allows you to have the shrinkwrap included into the doner object as an attachment. Of course it does not say that, just some other nomenclature that is somewhat confusing. Anyway problem solved!
