Is there any PTC documentation related to Performance Benchmark test - Soft Typing versus Hard Typing ?
I guess that performances between soft typing and hard typing are the same and depend only from amount of the attributes and attributes sizes. If type A has more attributes then type B, so A will stored slowly then B.
There are not many documents that mark the performance differences between modeled and soft types.
I was able to find some testing that was done on attributes. (see below) (blank shows normal response times)
| Modeled Attribute | Standard Attributes | Global Attributes | |
| Structure Navigation & Where Used | Higher | ||
| Folder Listing | Higher | Higher | |
| Create | Higher | ||
| Retrieve | Higher | ||
| Checkout | Higher | ||
| Update | Higher | ||
| Checkin | Higher | ||
| Delete | Higher |
In the Database Modeled Types have their own table as opposed to Soft Types.
The concern being that if you have a lot of Soft Types you may need to check the indexing to ensure the same performance.
Here is an article that I found that mentions using caching to prevent some small performance issue when using many soft type and attributes.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28189&source=tssearch
You can also find the instructions for the Modeled to Soft Type utility in the Customizers guide here:
http://support.ptc.com/WCMS/files/154113/en/10_1_M040_WindchillCustomizationGuide.pdf#150
Hope this helps, and good luck with your implementations!
Jarrett
Thank you for your help. It helps.
Helena
