Does anyone know if SolidWorks 2015 files can be integrated in Windchill 9.1 or where I can find a matrix that shows what versions of SolidWorks are compatible with Windchill 9.1
Thank you
on ptc.com go support, then under quicklinks (likely bottom left) there is a reference documents link. You're looking for the equivalent of Windchill102M030CADIntegrationMatrix_081315.pdf but for which ever version you need to use.
SW 2015 is not supported for 9.1 even if you are on M070
Thank you,
Binesh Kumar
Barry Wehmiller
Thank you Binesh and Steve for your answers. Very helpful...
