Solved: - Major PDMLink problem, LDAPrelated
sdrzewiczewski
7-Bedrock
The user just needs to have read access, it will not be used to change
any permissions. I would also suggest that they don't set that account
to change the password every X number of months or you will run into
another situation like this, unless that is you plan for it and
proactively reset the password and update the necessary files on your
install.
Steve D.
Quoting Mike Gamber <->:
> IT restarted the domain controller specified in the
> app-Windchill-Auth.conf file and now we are running again. They also
> monkeyed around with the permissions on the user specified in that
> file on AD (made it a domain admin) but we are not sure if it needs
> to have those permissions.
> Anyone know the exact permissions necessary for the user specified
> in the app-Windchill-Auth.conf file?
0 REPLIES 0
