Standard Alphabetic Versioning Scheme
aachanta
Hi All,
Can you please answer below 2 questions on Versioning Scheme ?
1. ) Can I use an Alphabetic Versioning Scheme for a sub type object and a Numerical Based Versioning Scheme for its parent object ? Like to elaborate it, I want to use Numerical Versioning Scheme to "WTPart" and Standard Versioning Scheme to its sub type "CustomPart" ? Is it possible in Windchill ?  Can you please let me know about it once ?
2.) If I am using a Standard Alphabetic Versioning Scheme for both WTPart and its subtype CustomPart and if I dont want to use or skip the characters like A, D, G, I, K, L, M etc. only for its subtype CustomPart but not for WTPart. How would I do that ? Can you please let me know about it once.
Can you please brief me on these two queries.
Thanks in advance.
Best Regards,
Aditya Achanta
satre-2
(To:aachanta)
Aditya,
You can create two separate OIR for WTPart and custom Part and In OIR mention which version series you want to use for each type.
    <!--  set the version info to a generated version info -->
<AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
<Arg>wt.series.HarvardSeries</Arg>
</AttrValue>
If you are using file based series then you can add legacy=true in series to skip the latters if you can specify skip list in wt.properties using below properties  wt.series.MulticharacterSeries.MilSpec.skipList
Hope it helps !!!
Shreyas
9405954712
satre-2
(To:aachanta)
Aditya,
</AttrValue>
Hope it helps !!!
Shreyas
9405954712
aachanta
(To:satre-2)
Hi Shreyas,
Thank you.
Upon adding the characters that are to be excluded in the skiplist will that be reflected for all objects ?
Like as I said i want few characters to be skipped only for CustomPart but not WTPart. So will this be skipped for WTPart as well ? Can you please let me know about it once.
Best Regards,
Aditya Achanta
