Hi All,
We are planning to create substring Index on Windchill table(column) "WTPartmaster(WTPartNumber)" in order to Optimize Leading and Trailing wildcard search strings like *ABC*.
I wanted to know If someone has implemented it. What are the challenges? Any performance overhead during table syncing.
I will really appreciate your inputs/suggestions with this. Thank you in advance!
It looks like you've already read through the reference materials for Substring Indexes. So I'll just try to expand on them a bit.
@AndrewMichaelAr Thank you so much for your inputs. Also, can you please share If this is implemented by someone you know?
Hi All,
I would really appreciate if anyone can share his/her thoughts regarding challenges faced (If any) after implementing substring Index on Windchill table(column). We are also planning to implement this.
Thanks!
Hi All,
Thanks!
