We've got some legacy data that uses an old versioning series. Is it possible to change the versioning series that an object uses? I'm assuming that some java/jsp/something along those lines would be needed.
I thought I saw a post on here, but was unable to find it searching...
Thx,
Steve D
Has anybody been able to switch the versioning series an object uses after it's been created?
Thanks for the replies. Tech support actually came through and it was a very easy fix.
So my main issue was the original versioning series was MilSpec which goes -, A, B, C etc... The new series was StateBased which goes 1,2,3,4...,A,B,C
So there is never a - in the new series. The solution was to export the filebased versioning series, modify the Numeric Seed and put a - before the 1. Upload the series and restart. All the errors went away, I was able to Revise, Reassign Lifecycle and find the objects in search results.
Now my issue is all parts start with a - and we want them to start with the 1, so i'm about to edit the filebased series again and put the legacy="true" on the - element. So it's a valid legacy version, but new objects won't use it.
