Syntax for OIR of soft-type
davehaigh
I've created a new soft-type under the Document type called First Article Inspection Report.
I'm confused as to the syntax I need in the OIR to associate it to this soft-type.
The 1st line of thedocument OIR looks like this:
<attributevalues objtype="wt.doc.WTDocument">
How should that be changed so it refers to the correct sub-type of WTDocument? Or don't I change that at all.
Dave Haigh
Hover your mouse in the Type Manager over the created type and you'll see it. Add that to the type above it with the pipe (|) character as a separator.
Example for OTB Reference Document: wt.doc.WTDocument|com.ptc.ReferenceDocument
The first line of your OIR will say something (replace with your type): objType="wt.doc.WTDocument|com.ptc.ReferenceDocument">
