As far as I know you can't create a workspace with the API while Pro/E is in full visible mode. You can only create it if Pro/E started with the Batchmode Option. The only way to create one programaticly while Pro/E is full visible is a mapkey.
Has someone other excperiences with this thematics ?
Best regards,
Eike
