Table with Text box in windchill
adev
Is there any way we can create the Textbox in the component builder and a search button
Please help if any body know this
Hi Ankit,
As mentioned earlier, the second link should be helpful.
Also, you may want to try following to get started. It's not a complete example though.
1. Create a jsp with a simple form, you can also do this by creating attribute panel
<input type="text" size="25px" id="EnterNumber" name="EnterNumber" value="">
<input type="text" size="25px" id="EnterName" name="EnterName" value="">
  <input type="button"  id="SubmitButtonID" name="SubmitButtonID" value="Search" onClick="submitFunction();">
<div id="mvcTable">
  <mvc:tableContainer compId="<<YOUR COMPONENT ID>>" height="600" />
  </div>
2. Include the JS
function submitFunction() {
  var number = document.getElementById('EnterNumber').value;
  var name = document.getElementById('EnterName').value;
  var params = {
  number : number,
  //reload the table builder
  PTC.jca.table.Utils.reload('<<YOUR COMPONENT ID>>',params,true);
3. In your builder you should be able to get the parameters as shown below
public Object buildComponentData(ComponentConfig  config, ComponentParams params) throws Exception {
  String PartNumber= (String) params.getParameter("number");
  String PartName = (String) params.getParameter("name");
Bhushan
Are you creating a Wizard? Can you check following links on your server to see if that helps.
http://<<HOSTNAME>>/Windchill/app/#netmarkets/jsp/componentCatalog/wizardComponent.jsp
http://<<HOSTNAME>>/Windchill/app/#ptc1/comp/carambola.testClients.search
Bhushan
Hello Bhushan,
No I am not creating a Wizard I like the functionality like search where I can input some values and as per that I will get the result
Ankit
Hi Ankit,
<div id="mvcTable">
  </div>
2. Include the JS
  var params = {
  number : number,
Bhushan
Thank you so much Bhushan for your help
