Hi Team,
Facing a challenge in Target Release State.
The target release state in Change Notice gets auto-change to other state on submitting CN
Eg:
Target Released State available ; Developlment, Released.
When select Released as target, it auto changes to develompment on submitting CN.
Any references would be of great help.
WC version: 12.0.2.3
In the LC template for that object , please check the following .,
1. Check if "Development" is before "Released" in the LC sequence
2. Check the tab "Change" in the LC transitions area. You must be able to see that object can transition to "Released" only from certain states.
3. If nothing is defined in that "Change" transition, then it will default to Initial State like happened to you.
With a screen of the above configurations, we can help further.
Cheers
Hari
