Tom,
You can grant modify permission using life cycle.for example: life cycle is as followsOpen-In work- approved- released- obsoleted and you want to grant modify permission only in "In Work" state for designer(only one user), you can use below approach
1.Modify the objects team template and add role Designer (you can add role as per your setup)
2.Modify the life cycle and grant modify permission in "In Work" state for designer role3.When you want to give modify access to particular user add that user into objects team in designer role.
If you want to grant permission only using workflow activity then grant modify permission on “primaryBusinessObject” in activity variables(make sure workflow is running on the object for which you want to grant the permission )
See attached for details
--Shreyas
Yes. life cycle access control permissions supersede domain permissions.see attached mangae security window for desc user
Shreyas
