booleans use up less memory and compare faster is why i used them...., also they can be scaledto put on each transitionwhich produces less checking.also ifyou want it not to wait then check for that an throw it to an OR that terminates the before procedings. Ands work good for your situation but i would use booleans with the or condition to kill the others. Just a personal preference. Because i like to see what the booleans are set to in the process manager and i can back track why they got that way fast.
