Thumbnail Navigation Pop-up on Hover.
Phillip1
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.0.1
In Commonspace view, there is an option to have a column called "thumbnail navigation". In is helpful to have this column visible, but I would like to turn off the popup on hover function? I would like to be able to click on the image to view the information when I want to see it and not have it block visibility of other columns every time the mouse passes over it.
avillanueva
23-Emerald I
(To:Phillip1)
I could not find a switch or preference to disable this. I suspect that the trigger is some javascript function that you maybe able to disable through customization.
@Phillip1.. there are couple of javascript functions related to WVSPopup and mouse over in \netmarkets\javascript\util\windchill-all.js, but I won't recommend modifying the javascript file directly.
Sandeep S Desai
