To change how "multi-evaluated" Strings are displayed
ptc-4635701
I have a "multi-evaluated" String global attribute. After having edited it, I display the object, then the values are automaticaly sorted alphabeticaly.
Indeed, the values are recorded randomly in database. They should be recorded and displayed as they were entered by the user.
Steps to reproduce:
1) Create a global attribute of type String in a Windchill type (for instance a WTDocument).
2) Do not put the "Single-Valued" constraint
3) Put the "Suggested Value List" constaint and let this list empty.
4) Create an instance of this object. Set several values for the new attribute. For instance A, C, B.
5) Display the attributes of the new object: you see A, B, C. The values are automaticaly sorted and not displayed as entered.
0 REPLIES 0
