Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Does anyone know if there is a configuration setting to control the number of items that can be sorted by column type? When performing a search that returns a larger set of data, certain columns can't be sorted. (See picture below.) The un-sortable columns include the following:
* Changed Status
* Checked Out By
* Created By
* General Status
* Modified By
* Shared Status
* Version
This is with Windchill 9.1 M050. The behavior is not browser dependent. Any ideas? Thanks.
[cid:image001.png@01CDC249.2D1A1E60]
Tom Uminn Engineering Systems Analyst trans-matic Mfg. 616-820-2499 -<">mailto:->
