Trouble finding location of xconf.dtd
  • July 29, 2015
  • 2 replies
  • 1696 views
I am trying to locate xconf.dtd file. I tried searching in the Windchill folder, but could not find it. If anybody has any idea please revert.
Best answer by ChrisSpartz
The xconf.dtd file should be in your install.jar file in <Windchill>/codebase/WEB-INF/lib/. Inside the jar file, it's located in the directory com/ptc/windchill/structconf/xconf/
It is not on my 10.2 M030 server...
Unix command:
find $WT_HOME/ -name xconf.dtd -print
returns no results, whereas:
find $WT_HOME/ -name wt.properties -print
returns results, so I know the command works.
$WT_HOME/codebase/wnc/CommonCore/wt.properties
$WT_HOME/codebase/wt.properties
