Redefining the placement of one object in an assy, after a save most released hardware are either modified or show with new status with not eligible for upload and are not out of date. WC won't allow me to syncronize or add/download content from commonspace.Config.pro is set to changed and specified, no datums or layers etc were manipulated.
Try setting the config option save_objects to "changed_and_updated" to see if it yields the desired/expected behavior. You may also want to investigate the propagate_change_to_parents config option in conjunction with the save_objects setting.
From the UsingProeWithWindchillGuide:
• The configuration file option save_objects is set to all. In this case,The configuration file option save_objects is set to all. In this case,The WC Add to Workpace defaults to 'Reuse', we change to download to overwrite WS contents. The reuse option is great to have.
I do wish that Add/Update/Syncronize could have been consolidated into one function.
We are playing with the Pro/E config regenerate_read_only_objects so that Pro/E does not even modify them.
