Thanks to Jim Vandragt. I set the following property which made Java use it's 64 bit model.
<property name="wt.manager.cmd.common.java.extra.args" overridable="true"<br"/> targetFile="codebase/wt.properties"
value="-d64"/>
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image001.jpg@01CA5D61.7CAB1C40]
