How to unassociate CAD documents from the lower version of a WTpart in Windchill 9.1? . Current version (version-0.4) is not attached with this CAD drawing anyway.
What I mean is:- I was trying to delete a CAD drawing associated with a lower version of a WTpart.
I get following error message:-
A referential integrity violation occurred for this operation:
Can not delete master "XXXX000043" that is usedBy following versions : YYYY0005, 0.3 (Design)
in order to delete the CAD drawing you have to delete also the iteration of the "lower" version of the WTpart. You can do that on the property page of the wtpart => Actions > Delete Non-latest iterations.
Regards
Klaus
Regards
Klaus
Thank you very much.
