All,
I have been using Windchill 10.1 M040. But I want to uninstall it completely and again I want to try installing it.
Is there any procedure to uninstall windchill completely from your local machine? If so Please share the documents or tell me the procedure. Thanks in advance.
Parth..
Parth,
The following steps for the complete uninstallation of Windchill and Oracle from Windows.
1. Uninstall WindchillDS using the WindchillDS uninstaller from " \WindchillDS\server\uninstall.bat "
2. Delete the Windchill database using Oracle’s DBCA (Database Configuration Assistant) utility. DBCA can be launched from "Start->All Programs->Oracle->Configuration and Migration Tools-> Database Configuration Assistant"
3. Uninstall Oracle using Oracle uninstaller from "Start->All Programs->Oracle->Configuration and Migration Tools-> Oracle Installation Products-> Universal Installer"
4. Reboot the system
5. Delete the "Windchill_10.0" menu from "Start->All Programs"
6. Delete the following folders: 1.C:\Oracle
2.C:\tmp\ptcServlet
3.C:\ptc\Windchill_10.0
4.C:\Program Files\Zero G Registry (hidden folder)
5.C:\Program Files\Oracle
6.C:\Documents and Settings\<windows_username_who_installed_windchill>\.wt
7.C:\Documents and Settings\<windows_username_who_installed_windchill>\InstallAnywhere (hidden folder)
8.C:\Documents and Settings\<windows_username_who_installed_windchill>\lbe
9.C:\Documents and Settings\<windows_username_who_installed_windchill>\Application Data\PTC\Windchill
Please note that uninstalling Oracle does not remove all registry entries. These entries must be manually removed
Hope this helps!!!
thanks,
Shreyas
