Does anyone know if global enumerations can be added using an excel, csv or xml file using LoadFromFile or other tool? I have a list that is 250 rows and I do not want to type in each one.
Yes this is possible.
I had a lot of lists to upload.
Here is my template for each item:
<!-- enum membership -->
<csvBeginEnumMemberView handler="com.ptc.core.lwc.server.BaseDefinitionLoader.beginProcessEnumMembership">
<csvname>«code»</csvname>
</csvBeginEnumMemberView>
<!-- entry properties -->
<csvPropertyValue handler="com.ptc.core.lwc.server.BaseDefinitionLoader.processEnumEntryPropertyValue">
<csvname>displayName</csvname>
<csvvalue>«description»</csvvalue>
</csvPropertyValue>
<csvname>description</csvname>
</csvPropertyValue>
<csvname>tooltip</csvname>
</csvPropertyValue>
<csvname>selectable</csvname>
<csvvalue>true</csvvalue>
</csvPropertyValue>
<!-- entry link properties -->
<csvPropertyValue handler="com.ptc.core.lwc.server.BaseDefinitionLoader.processEnumMembershipPropertyValue">
<csvname>sort_order</csvname>
<csvvalue>«rank»</csvvalue>
</csvPropertyValue>
<csvEndEnumMemberView handler="com.ptc.core.lwc.server.BaseDefinitionLoader.endProcessEnumMembership"/>
You may find a complete xml file in the default dataload files.
I hope this helps,
VA
