User is unable to submit or save tasks.
AQ_10299550
8-Gravel
The user is encountering an issue where the Actions tab is grey'd out for her as well as not having a save/complete task within the 'My Tasks' table.
Within further investigation of the workflow, we appear to encounter this error prompt.
"ATTENTION:
The (Company Name) Document - (Document COA), (Document Name), (Library Name), 1.1 object cannot be submitted at this time. To compelte this action, you must have a submit work item for this object. You will receive this work item when the Submit task is active in the appropriate Workflow.
What are the ways to solve this issue?
HelesicPetr
(To:AQ_10299550)
Hi @AQ_10299550
Try to add a admin rights to the user and check if can finish task.
If so there is ACL trouble and it can be cased by several things
Also the task has to be set as a set-up participant task in the workflow.
PetrH
HelesicPetr
(To:AQ_10299550)
Hello @AQ_10299550
It seams that user does not have correct ACL rights on the workflow tasks.
Check if the user is in the context team, and also if the user is assigned to a organization.
Few days/weeks ago someone had similar problem with tasks where he could not complete the task because user had accidently been removed from organization. User didn't see the complete / save button.
PetrH
Hello @HelesciPetrYes, when I'm done
Unfortunately after addingACL rights in the workflow the issue continues to persist. She is also within the right organization(group) that was set up.
To note, a subprocess was removed within the workflow and the error prompt does not show up. But, the user is now not getting the "set-up participant" task, but the admin account our company created is getting it instead.
HelesicPetr
(To:AQ_10299550)
Hi @AQ_10299550
PetrH
