Using PSI intasll Windchill but failed at InfoEngine configuration, how to fix?
DEBUG 2023-10-16 11:17:00 - Installation is Aborting. The installation cannot continue.
FATAL 2023-10-16 11:17:40 - Aborting installation.
FATAL 2023-10-16 11:17:40 - Installation is Aborting. The installation cannot continue.
FATAL 2023-10-16 11:17:40 - java.lang.Exception: deploy failed for (ie) with return code = 1
FATAL 2023-10-16 11:17:40 - aborting: original exit_code = 2
FATAL 2023-10-16 11:17:40 - aborting: normalized exit_code = 2
DEBUG 2023-10-16 11:17:40 - SHUTDOWN REQUESTED
DEBUG 2023-10-16 11:17:40 - (X) commiting registry
DEBUG 2023-10-16 11:17:40 - (X) shutting down service manager
DEBUG 2023-10-16 11:17:41 - (X) cleaning up temporary directories
DEBUG 2023-10-16 11:17:41 - Exiting with exit code: 2
DEBUG 2023-10-16 11:17:42 - cleanUp()
DEBUG 2023-10-16 11:17:42 - calling cleanUpWin32()
WDS running?
Are there any special characters in the password of cn=Manager user?
Check them
WDS running?
Check them
Yes, WDS is Windchill Directory Server.
Hi @Rocket_Max
Successfully installed, I changed my password to no special characters. thanks!
-Zhangyue
