Vaulting on Cluster
rkalbhor
2-Explorer
Vaulting on Cluster
Hi All,
PTC's current Clustering document shows that we're supposed to create 2
hosts in Ext. Storage Admin. Those 2 hosts should have one folder
destination which should be available to both of the slaves. So keeping that
in mind when I create one folder on Slave1, it validates successfully and
data is uploaded. But when I am logged into another slave(slave2) and try to
check-in it gives me the below error. How should I go in to validate the
folder against Slave2?
Wed 5/11/11 16:09:48: RMI TCP Connection(21)-127.0.0.1:
(wt.fv.uploadtocache.uploadtocacheResource/11) wt.util.WTException: Cannot
save: Local mount does not exist
Wed 5/11/11 16:09:48: RMI TCP Connection(21)-127.0.0.1: at
wt.fv.uploadtocache.DoUploadToCache_Server.storeContentInVaultOnMaster(DoUploadToCache_Server.java:518)
wt.fv.uploadtocache.DoUploadToCache_Server.doMultiPartUploadToCache_Server(DoUploadToCache_Server.java:1016)
wt.fv.uploadtocache.DoUploadToCache_Server.doUploadToChache_Master(DoUploadToCache_Server.java:83)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
wt.httpgw.HTTPServer.processRequest(HTTPServer.java:342)
wt.httpgw.HTTPServer.processRequest(HTTPServer.java:208)
wt.httpgw.HTTPRequestImpl.readExternal(HTTPRequestImpl.java:222)
java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:1792)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1751)
java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1329)
java.io.ObjectInputStream.readObject(ObjectInputStream.java:351)
wt.method.MethodArgsReader.readExternal(MethodArgsReader.java:180)
wt.method.MethodArgs.readExternal(MethodArgs.java:160)
sun.rmi.server.UnicastRef.unmarshalValue(UnicastRef.java:306)
sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:290)
sun.rmi.transport.Transport$1.run(Transport.java:159)
java.security.AccessController.doPrivileged(Native Method)
sun.rmi.transport.Transport.serviceCall(Transport.java:155)
sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:619)
Rohan Kalbhor
Email:-
If it's a windows server, map the network drive to the folder location
on slave 1 and then use this location in the Mount option.
For ex, if you are creating a folder on slave1 on as D:\vaults\test01
map this folder to slave 2 as <drive letter=">:\vaults and then in the
mount option for slave 2 use <drive letter=">:\test01 as the folder path
and then validate.
Best Regards
Rajesh Balasundaram
