When using the NamingService.newInstance(namingServiceName,props) method in my Java code on the client, I get the error below for the NamingServiceException.
No exception of type NamingServiceException can be thrown; an exception type must be a subclass of Throwable
Not sure what is going on but has anyone experienced this issue? I am using WC10.0.
Thanks for any help.
Ok I found the problem. You will need to add the servlet.jar file to the library of your IDE. The jar file is located in the Windchill srclib folder.
Thanks.
In Reply to James Felkins:
