Is it possible to create an attribute on a object (CAD Doc) that when the objects iterates (check-in or revise), the previous value of the attribute will not copy forward?
We have atleast 3 business use cases for this, but unfortunately it is not available out of the box . There are several product ideas on this - Reset attribute values during "save as" & revise
In our case, it was not for CAD docs and had a workflow running on those object so we added expressions to clear the value of the objects on Save as.
One option is to write a listener that would listen for NEW_VERSION event, filter out check outs from the event, verify the existence of a prevision version which is not wip and use pers. adapter api to reset the value of the attributes. It is not a light customization considering that we have to add a listener to CAD document (most used object type in most of WC). It is so unfortunate that, this is not available out of the box
Bummer. Thanks for letting me know.
