Video card with ProEngineering wildfire 4 M160
MPernumi
Hi all,
I have wildfire 4 M160 with windows 7 x64 and the videocard nvidia fx580.
I've installed the driver suggested by ptc for my workstation but happens a strange thing.
Every time that I work with quotas there is the screen that blink. This happen only with I put the mouse inside quotas in my drawings.
There is some patch or something that I have to set with this release.
I've tried with another videocard fx3700 but the same behaviour...
Please, if you have some suggestion inform me.
Thanks a lot
Matteo,
put graphics win32_gdi option at the end of your config.pro file and test the problem once again. If is not reproducible, then drivers are wrong. Try to install newer or older ones. Don't forget to remove graphics win32_gdi option from your config.pro file.
Martin
Martin Hanák
Martin, I've tried with your suggestion adding from pro/e the option graphic32 gdi instead of opengl but without results.
The problem is reproducible so I've see immediately the results...
It's very strange ecause my video card seems certified from ptc with drivers 191.78
191.78 -
Supported OS: Win7 64
Supported Graphics Cards: FX380, FX580, FX1800, FX3800
OEM: HP z200, HP z400, HP z800
from your suggestion I will try with newer drivers or older drivers.
Thanks for the moment. bye
